Issue with Authentication & IP Phone
Jason Weids
We are experiencing an issue with authenticating user PC's on the network when they are connected through a Cisco IP phone. This was previously working fine, but since a switch IOS upgrade, we are seeing sporadic errors where the users MAC address does not appear on the port.
Below is our switchport config that has been working & is working just about everywhere else apart from in a few odd areas. The switch is a C2960X running version 15.2(6r)E
interface GigabitEthernet3/0/23
switchport access vlan 101
switchport mode access
switchport voice vlan 108
authentication event fail action next-method
authentication host-mode multi-auth
authentication open
authentication order mab dot1x
authentication priority mab dot1x
authentication port-control auto
authentication timer reauthenticate server
mab
snmp trap mac-notification change added
snmp trap mac-notification change removed
dot1x pae authenticator
dot1x timeout tx-period 2
spanning-tree portfast edge
end
When using the config above we see the phone is working in voice VLAN but we do not see the PC MAC address.
NPCM202-A-1#sh mac ad int gi3/0/23
Mac Address Table
Vlan Mac Address Type Ports
108 005f.8691.99eb STATIC Gi3/0/23
Total Mac Addresses for this criterion: 1
If we change the config on the port & remove all the authentication config & statically assign the access & voice VLAN as below then the MAC address of the PC then shows up. Authentication is done by Cisco ISE policy using MAB
switchport access vlan 200
mls qos trust cos
end
Mac Address Table
108 005f.8691.99eb DYNAMIC Gi3/0/23
200 005f.8691.99eb DYNAMIC Gi3/0/23
Total Mac Addresses for this criterion: 2
0 Replies 0
