Issue with IOS upgrade N5K-C5548UP
                   Hi, I have problems to do an IOS upgrate of N5K-C5548UP, i have the next error:
switch(config)# install all kickstart bootflash:n5000-uk9-kickstart.5.1.3.N2.1b.bin
Verifying image bootflash:/n5000-uk9-kickstart.5.1.3.N2.1b.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n5000-uk9.5.1.3.N1.1a.bin for boot variable "system".
Verifying image type.
Extracting "system" version from image bootflash:/n5000-uk9.5.1.3.N1.1a.bin.
Extracting "kickstart" version from image bootflash:/n5000-uk9-kickstart.5.1.3.N2.1b.bin.
Extracting "bios" version from image bootflash:/n5000-uk9.5.1.3.N1.1a.bin.
Recommended action::
"Module 1 might not be supported in the new image,
it should be powered off before proceeding with install".
Performing module support checks.
Notifying services about system upgrade.
Compatibility check is done:
Module  bootable          Impact  Install-type  Reason
     1        no             n/a           n/a  Incompatible image
Images will be upgraded according to following table:
Module       Image         Running-Version             New-Version  Upg-Required
     1      system            5.1(3)N1(1a)            5.1(3)N1(1a)            no
     1   kickstart            5.1(3)N1(1a)            5.1(3)N2(1b)            no
     1        bios      v3.5.0(02/03/2011)      v3.5.0(02/03/2011)            no
     1      SFP-uC                v1.0.0.0                v1.0.0.0            no
     1   power-seq                    v1.0                    v1.0            no
     3   power-seq                    v5.0                    v5.0            no
     1          uC                v1.2.0.1                v1.2.0.1            no
switch(config)#
switch(config)#
switch(config)# show ver
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_serie
s_home.html
Copyright (c) 2002-2012, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 3.5.0
  loader:    version N/A
  kickstart: version 5.1(3)N1(1a)
  system:    version 5.1(3)N1(1a)
  power-seq: Module 1: version v1.0
             Module 3: version v5.0
  uC:        version v1.2.0.1
  SFP uC:    Module 1: v1.0.0.0
  BIOS compile time:       02/03/2011
  kickstart image file is: bootflash:///n5000-uk9-kickstart.5.1.3.N1.1a.bin
  kickstart compile time:  2/7/2012 23:00:00 [02/08/2012 07:49:30]
  system image file is:    bootflash:///n5000-uk9.5.1.3.N1.1a.bin
  system compile time:     2/7/2012 23:00:00 [02/08/2012 12:44:33]
Hardware
  cisco Nexus5548 Chassis ("O2 32X10GE/Modular Universal Platform Supervisor")
  Intel(R) Xeon(R) CPU         with 8263880 kB of memory.
  Processor Board ID FOC16430F1H
  Device name: switch
  bootflash:    2007040 kB
Kernel uptime is 0 day(s), 1 hour(s), 23 minute(s), 15 second(s)
Last reset
  Reason: Unknown
  System version: 5.1(3)N1(1a)
  Service:
plugin
  Core Plugin, Ethernet Plugin
switch(config)#
switch(config)# poweroff module ?
  <2-4>  Please enter module number switch(config)# poweroff module ?
Can you tell me how can I upgrade this device?
Best regards.
Leo Laohoo
Are you trying to install a Layer 3 daughter card?
Hi leolahoo, I´m just trying to upgrade the N5K-C5548UP without install any card, but i have the next error:
Do you know how can I solve this issue?
After the upgrade did you turn off the switch completely and than turn it back on?
After a successful power sequence upgrade, you must switch off the power to the system and then power it up.
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/upgrade/513_N1_1/n5k_upgrade_downgrade_513.html
Hi Reza, i was using an bad command, the right one is:
install all kickstart bootflash:n5000-uk9-kickstart.5.1.3.N2.1b.bin system bootflash:n5000-uk9.5.1.3.N2.1b.bin
Now the Nexus is upgraded:
switch# show ver
s_home.html
Software
  BIOS:      version 3.5.0
  loader:    version N/A
  kickstart: version 5.1(3)N2(1b)
  system:    version 5.1(3)N2(1b)
  kickstart image file is: bootflash:///n5000-uk9-kickstart.5.1.3.N2.1b.bin
  kickstart compile time:  8/31/2012 17:00:00 [09/01/2012 00:30:27]
  system image file is:    bootflash:///n5000-uk9.5.1.3.N2.1b.bin
  system compile time:     8/31/2012 17:00:00 [09/01/2012 01:29:34]
Hardware
  Intel(R) Xeon(R) CPU         with 8263864 kB of memory.
  Processor Board ID FOC16430FMS
  Device name: switch
Kernel uptime is 0 day(s), 0 hour(s), 3 minute(s), 25 second(s)
Last reset at 131600 usecs after  Fri Jan 30 00:37:29 2009
  Reason: Disruptive upgrade
  Service:
plugin
switch#
Thanks and best regards!!!
Fernando
