Issue with nat routing
jimwysocki
What I am trying to do is take all traffic from the 192.168.226.X network and pass it onto the 192.168.225.X network. But what I also want is for the traffic from 192.168.226.X destined for the 172.X.X.X network to be natted. But as my configs are now the only ips I can access from the 192.168.226.X network is the 172 subnet. Any pointers would be greatly appreciated.
version 12.3
service password-encryption
hostname SFS-VPN-Router
boot-start-marker
boot-end-marker
enable secret xxx
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
interface Ethernet0
description VPN interface
ip address 192.168.226.1 255.255.255.0
ip nat inside
full-duplex
interface FastEthernet0
description SFS interface
ip address 192.168.225.241 255.255.255.0
ip nat outside
speed 100
full-duplex
ip nat inside source route-map nat interface FastEthernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.225.123
ip route 172.18.11.13 255.255.255.255 192.168.225.3
ip route 172.18.91.143 255.255.255.255 192.168.225.3
ip route 172.29.53.144 255.255.255.255 192.168.225.3
ip route 172.29.53.145 255.255.255.255 192.168.225.3
no ip http server
no ip http secure-server
access-list 101 deny ip any 192.168.225.0 0.0.0.255
access-list 101 permit ip any any
route-map nat permit 10
match ip address 101
line con 0
line aux 0
line vty 0 4
password xxx
login
jimwysocki
My bad, I needed reverse routes on the PC
