Issue with PXE build with switch port
Hi I have a problem with switch port . the issue is when engineer is trying to do PXE build by connecting laptop directly to the swithc port he is getting error,the same he is connecting to ip phone from switch port and phone to laptop he is able to do the PXE build ,.
please help me to resolve its bit urgent to resolve the issue.
luckymike33
Is it possible that spanning-tree is taking longer to put the port in forwarding condition than the PXE process is allowing?
I would try putting the port in spanning-tree portfast mode. If that doesn't work - can you paste the output of 'show interface [interface] switchport'
and show run interface [interface]
Best wishes
Mike
luckymike33
Best wishes
Mike
this is the configuration:-
interface GigabitEthernet13/30
 switchport
 switchport access vlan 80
 switchport mode access
 switchport voice vlan 96
end
thank you verymuch dear after enabling thr STP its start working awasome thanks a ton
