Issues with 4x10G LACP
jmperlewitz
I have very strange behavior with our 4x10G port-channel on a 3650-48FD-L switch-stack.
I have 2 switches and have created a port-channel with 2 10G ports from each switch to create a total of 40G.
When all 4 10G interfaces are up, we are losing packets when we do ICMP pings.  However, when I shut one of the links down, the packet-loss goes away.
For example,
Success rate is 98 percent (494/500), round-trip min/avg/max = 2/4/40 ms
Then I shut  Te2/1/3
show platform software fed switch active etherchannel 1 load-balance mac 00ee.abe0.cb00 002f.5c1a.ed80
Dest Port: : TenGigabitEthernet2/1/3
Packet loss is gone:
Success rate is 100 percent (500/500), round-trip min/avg/max = 2/4/56 ms
There is no CoPP policy.  I have tried enabling the qos queue-softmax-multiplier 1200 command but the issue still persists.
Thoughts?
Reza Sharifi
Can you post the output of "sh run" from both switches? Are the physical interfaces showing any packet drops?
