IT Administrator
I have a Cisco ASA 5505, with IPSec VPN configured.  Everything was working just fine, until I needed to disable Split-Tunneling.  Basically, we need to have all computers connected to the VPN to have their internet connection go through the ASA.  So, the problem is, now that I have made the changes to remove split-tunneling my users are unable to access the local LAN, so the VPN is working, and the traffic is going through ASA, but we are not able to connect or even ping any local LAN servers.  Below is my running-config file, please let me know what I did wrong and what am I missing.
Thank you for help.
ASA Version 8.2(5)
names
name 10.250.250.0 VPNGroup description VPN Group
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 123.123.123.123 255.255.255.248 (public IP changed for security)
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit intra-interface
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit icmp any any
access-list outside_access_in extended permit icmp any any
access-list outside_nat extended permit ip VPNGroup 255.255.255.0 any
pager lines 24
logging enable
logging timestamp
logging buffer-size 1000000
logging monitor debugging
logging buffered debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool vpnpool 10.250.250.1-10.250.250.49 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 192.168.1.0 255.255.255.0
nat (outside) 1 access-list outside_nat
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 123.123.123.120 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map outside_dyn_map 20 set transform-set myset
crypto map outside_map 20 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 10
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.200-192.168.1.254 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DfltGrpPolicy attributes
dns-server value 8.8.8.8
nem enable
group-policy BisVPN internal
group-policy BisVPN attributes
vpn-idle-timeout 30
split-tunnel-policy tunnelall
split-tunnel-network-list none
split-dns none
username bisadmin password kfd;lsjflaksdjfklda encrypted privilege 15
tunnel-group BisVPN type remote-access
tunnel-group BisVPN general-attributes
address-pool vpnpool
default-group-policy BisVPN
tunnel-group BisVPN ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect http
service-policy global_policy global
prompt hostname context
Francesco Molino
I see that you're missing the may exemption.
Try that:
access-list nonat extended permit ip 192.168.1.0 255.255.255.0 10.250.250.0 255.255.255.0
nat (inside) 0 access-list nonat
Let me know if that worked
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Try that:
Francesco
thank you so much... that fixed it.
You're welcome
Francesco
