Jumbo Frames - What's the concensus on running it...
opers13
throughout the network...good or bad?
Please share your experience and thoughts..
thanks
Alex
Collin Clark
If you're 100% gigabit, you should see an improvement. If you have 100mb links anywhere the packets will get fragmented and most likely decrease performance at that point and beyond.
Hope that helps.
If you have a 6500 IOS switch, can the Jumbo frames be enabled at the port level or is this protocol enabled globally?
sK
You can enable per port, however not all linecards are supported. See the link for more details.
https://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml#c1
Thanks Clark,
SK
