jumbo frames
wholemans
Community Member
We are thinking of allowing jumbo frames in our server environment, especially for isci traffic, but i want to double check my interpretation before implementing this (devices to use are 65XX-Sup720 in VSS and 3750-E clusters.
Are the following assumptions ok ?
1) L2 devices don't fragment jumbo frames but just accept or reject them based on the defined mtu on the switch ?
2) L3 devices fragment jumbo frames if needed.
So in a network that only connects isci devices (clients and nas) in a L2 vlan, all switch ports should be jumbo frames enabled to make this work and there is no negotiation between end-stations about the maximum packet size.
Greetings,
Wim Holemans
Atif Awan
Wim,
Your assumptions are correct. Regarding your statement:
While there is no real negotiation in this case, you do need to consider the role played by TCP MSS. If you do not bump up the MTU of a server interface (leave it at 1500 for example) then it will report it's MSS as 1460 and any client establishing a TCP session with this server on the same segment will need to respect this value.
Atif
