Keepalive problem
theoddbeard
After connection Android device with JP1081 USB Ethernet adapter to Cisco 2960, the port to which the device is turned off. Android device with JP1081 operates in 10Mb/half-duplex.
What is the cause of failures and how to solve this problem?
The log shows the following entries:
ruekasw13#sh run int Fa0/20
Building configuration...
Current configuration : 51 bytes
interface FastEthernet0/20
  description -tv
end
Dec 18 05:49:25: %LINK-3-UPDOWN: Interface FastEthernet0/20, changed state to up
Dec 18 05:49:26: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/20, changed state to up
ruekasw13#
Dec 18 05:49:58: %ETHCNTR-3-HALF_DUX_COLLISION_EXCEED_THRESHOLD: Collisions at FastEthernet0/20 exceed threshold. Considered as loop-back.
ruekasw13#
Dec 18 05:49:58: %PM-4-ERR_DISABLE: loopback error detected on Fa0/20, putting Fa0/20 in err-disable state
Dec 18 05:49:59: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/20, changed state to down
ruekasw13#
Dec 18 05:50:00: %LINK-3-UPDOWN: Interface FastEthernet0/20, changed state to down
ruekasw13#sh int Fa0/20
FastEthernet0/20 is down, line protocol is down (err-disabled)
   Hardware is Fast Ethernet, address is 203a.0765.1314 (bia 203a.0765.1314)
   Description: -tv
   MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
   Keepalive set (10 sec)
   Auto-duplex, Auto-speed, media type is 10/100BaseTX
   input flow-control is off, output flow-control is unsupported
   Last input never, output 00:03:09, output hang never
   Queueing strategy: fifo
   Output queue: 0/40 (size/max)
      4377 packets input, 795370 bytes, 0 no buffer
      Received 487 broadcasts (51 multicasts)
      0 watchdog, 51 multicast, 0 pause input
      82202 packets output, 10111549 bytes, 0 underruns
      0 output errors, 162 collisions, 3 interface resets
Sandeep Choudhary
Hi Granov,
collisions are a just normal part of the half-duplex CSMA/CD procedure, and are not considered errors at all.  They are just retried.  They are not considered errors until a packet suffers 16 of them in a row, and has to be discarded - known as "excessive collisions".
1. Disable the keepalive with these commands:
Switch#config t
Switch(config)# int f0/20
Switch(config-if)# no keepalive
2. If you don't want to turn off loopback detection/shutdown, you should
definitely enable loopback recovery (off by default, requiring manual
reset, an *awful* default!):
errdisable recovery cause loopback
errdisable recovery interval 60
3. run no shut on the interface fa0/20
Dont forget to rate helpful posts.
