Key chain in EIGRP Named mode with HMAC-SHA
Muhammad Rafi
Hi All,
is it ok to use key chain with eigrp named mode hmac or hmac-sha itself is strong enough to prevent replay attacks without key chain?
Bilal Nawaz
Yes, this is correct. You do not need the extra key chain. Just use HMAC under eigrp named mode >> under interface >> enable hmac with key.
e.g.
Router-A(config)# router eigrp CISCO
Router-A(config-router)# address-family ipv4 autonomous-system 1
Router-A(config-router-af)# af-interface ethernet 0/0
Router-A(config-router-af-interface)# authentication mode hmac-sha-256 password
Router-A(config-router-af-interface)# end
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_eigrp/configuration/15-sy/ire-15-sy-book/ire-sha-256.html
hth.
Bilal
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
6 Replies 6
Bilal Nawaz
e.g.
hth.
Bilal
Thanks Bilal, why did you use 0 ? doesn't that mean disable encryption ? what I want to encrypt my password as well rather than in clear text
I specified 0 because i am entering the password as I know it, that does not disable the authentication, maybe encryption. If i was to enter 7 then i think the passwords are encrypted.
hth
Bilal
Router-A(config-router-af-interface)#authentication mode hmac-sha-256 ?
  <0-7>  Encryption type (0 to disable encryption, 7 for proprietary)
  LINE   password
can you explain this please ?
Sorry Bilal, we have had confusion here, I asked about the encryption and you  mentioned authentication and I thought you said encryption lol, but its all clear now.
Beside, is it good practice to use authentication on loopback interfaces ?
Hello Muhammad, I have not seen this being implemented on loopback interfaces, more often we are trying to protect the adjacency, not a loopback that we are trying to advertise out. Unless our control plane got compromised somehow, then we have more worries than just the loopback :) So summary is no, it is not really necessary on loopback.
