Kron backup job not working
Heitkamp
Hi Guys!
I want to make backups of my switch automatically. If I send the command via CLI the switch creates a backup but if I try to run a kron job it fails.
Does somebody has an idea?
That works via CLI:
show run | redirect tftp://10.10.10.10/switch-01.cfg
This kron config does not work:
kron policy-list Backup
cli show run | redirect tftp://10.10.10.10/switch-01.cfg
exit
kron occurrence Backup at 06:00 monday recurring
policy-list Backup
exit
Switch model: C2960X
IOS Version: 15.2(2)E6
Heitkamp
I found the solution.
The problem was, that I wrote
cli show run | redirect ...
instead of
cli show running-config | redirect ...
But thank you for your help!
5 Replies 5
Mark Malone
could use archive as another option instead of flash use tftp , would be a better feature for backups if there is a bug in that software
Your config looks right for kron
archive
log config
logging enable
hidekeys
path flash:Archive.cfg
maximum 2
write-memory
time-period 1440
Helpful link
https://www.ciscozine.com/how-to-use-archive-command-to-save-configuration/
no known bug listed in that version for kron , does it work by FTP through kron , have you tried that ?
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_2_e/release_notes/OL-32568.html
Heitkamp
instead of
cool , thanks for posting the fix someone will find it useful down the line
indeed, useful info
