KVM through Cisco LAN Switch (Catalyst 2900XL)
Wondering if there is away of sending KVM information through a Cisco LAN Switch?
Using KVM to Ethernet (and at the other end the opposite) converters?
Cheers
Craig.
Giuseppe Larosa
Hello Craig,
a Cisco LAN switch understands only ethernet frames.
you can look for the KVM over IP products.
For example our customer is installing avocent appliances in several regional offices to allow remote access to colocated servers.
see
http://www.avocent.com/Cyclades_OnSite_Series.aspx
Hope to help
Giuseppe
