L2 interface to L3 interface
vipinrajrc
Level 6
Level 6
Hi Experts,
Is it possible to convert a L2 interface to L3 interface????
Today i tried to configure IP address in 1811router. Interface fa6.
But it showed some error as "L2 interface is ot able to configure an IP address." I have enable "ip routing" in this router, but still same error message.
Is there anyway to do this????
Vipin
Thanks and Regards, Vipin
Hi Vipin,
The "switch modules in routers" vary a bit. I would guess that
yours might be like a one or two port router with a 9 port HWIC
ethernet module in it.
If it is you can do something like
create vlans 3, 4, 5, 6, 7, 8
interface FastEthernet2
switchport mode access ! may or may not be needed
switchport access vl 2
interface FastEthernet3
swit mode access ! may or may not be needed
sw access vl 3
int vl 2
ip address x.x.x.x
no shut
int vl 3
ip address y.y.y.y
no shut
You create vlans either with
conf t
vlan 2
vlan 3
end
or
vlan dat
vl 2
vl 3
exit
Latter roughly; may have forgotten.
You have to make a point of saving it anyway.
Think it may prompt.
On the 9 port HWIC it is not possible to
assign an IP address directly to a port.
Please rate the helpful posts.
Naidu.
7 Replies 7
cadet alain
to convert a L2 port to a L3 port the command is no switchport under the interface then you can configure an ip address.
I'm not sure though that you can do this on the switch module on a 1811.
Regards.
Alain.
I Have tried it...
It is showing like incomplete commanad..
Please see the following output..... Which one should i select??? Right now that port is conncted to a switch......
1811(config-if)#no switchport
% Incomplete command.
1811(config-if)#no switchport ?
  access     Set access mode characteristics of the interface
  mode       Set trunking mode of the interface
  priority   Set 802.1p priorities
  protected  Configure an interface to be a protected port
  trunk      Set trunking characteristics of the interface
  voice      Voice appliance attributes
Vipin
Hi vipin
Make sure the switch model. you can try # set system mode route it will work.
Ashish kumar
Hi Vipin,
sw access vl 3
int vl 2
ip address x.x.x.x
no shut
int vl 3
ip address y.y.y.y
no shut
conf t
vlan 2
vlan 3
end
or
vlan dat
vl 2
vl 3
exit
Naidu.
Hi Naidu,
Thank you very much........It is working.........
Vipin
Hi Vipin,
Glad my post helped you...Keep posting CSC
Naidu.
Yes, using #no switchport command you can make interface as L3 service. This command generally uses when we are going to configure ISP connection on sg350 switch.
Thanks & Regards
Ashish Kumar
