L2 policing on cat6500 L2 interface
ibrunello
I need to police ingress traffic on a layer2 ("switchport") interface.
Traffic is raw ethernet, so only L2 policying is usable.
Cat6500
Sup 720
Native mode
IOS 12.2(18)SXF13 adv enterprise
Already read config guides, but it takes a while to understand all concepts.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/qos.html#wp1750716
Any sample config, to make me understand better the concepts?
TIA
Ivan
Yep - but I suggest you review the numbers:-
50000000 - 50 megabits per second
1562500 - 1.4 megabits per second
The burst size should be x 2 the CIR - otherwise you will never reach the CIR and you will experiance TCP global synchronization.
HTH>
8 Replies 8
andrew.prince
Level 10
Level 10
From the URL:-
This is the modified IPPHONE-PC policy map, which includes the police command:
policy-map IPPHONE-PC
class CLASSIFY-OTHER
police 50000000 1562500 conform-action set-dscp-transmit default exceed-action drop
These are the police command parameters:
•The 50000000 parameter defines the committed information rate (CIR) for traffic allowed in this traffic class. This example configures the CIR to be 50 Mbps.
•The 1562500 parameter defines the CIR burst size for traffic in this traffic class; this example uses a default maximum burst size. Set the CIR burst size to the maximum TCP window size used on the network.
•The conform action keywords define what the policer does with CLASSIFY-OTHER packets transmitted when the traffic level is below the 50-Mbps rate. In this example, set-dscp-transmit default applies DSCP 0 to those packets.
•The exceed action defines what the policer does with CLASSIFY-OTHER packets transmitted when the traffic level is above the 50 Mbps CIR. In this example, exceed action drop drops those packets.
The MQC is quite clear, and I used to apply on routed traffic.
My problem is with definition of class-map.
How can I set "match everything" clause?
the outlined class use an acl matching "IP any any", but I'm not sure the traffic is all pure IPv4 (maybe some IPv6, or some pure ether frames).
any hint?
That is the "class default"
Anything else that has not been defined and does not match a class = class default.
then, using the standard MQC syntax:
class class-default
police 50000000 1562500 conform-action transmit exceed-action drop
and then apply to interface.
right?
HTH>
ok.
this is a good start.
will play with the aggregate policers at later stage.
Thank you.
Ivan
np - glad to help
according to Cisco docs, the second parameter is in bytes, not bits.
as a rule of the thumb, I usually set the burst BYTE value as 1.5 bits value, so I have a quite big burst cache.
