L2 routing
mohamed.ali
Dears,
i have a layer 2 link that when I put an IP on the same subnet there is connectivity.
note that in the layer to there is a direct connected network as well static route. so I need to make routing with layer 2 from my HQ .
what is your recommendation for the configuration?
use a L3 device (switch or router) for L2 link. make sub interfaces for each vlan which you need to connect in same subnet and one additional subinterface for for routing (static route)
