L2 Switch Layers
steve.ford
Community Member
Does anyone have any recommendations for the layer 2 switch topology? From my L2/L3 distribution switches I connect L2 edge switches. Can I continue to add L2 switches below the othyer L2 switches and not affect STP performance and recovery times?
Jagdeep Gambhir
Level 11
Level 11
Hi ,
You can set up that way, it should not have any impact on STP or any other performance issue. I would suggest not to have more then 2/3 hops of L2 switches.
~JG
