L2 switch management
a.alyahia
i have a layer two switch with vlan 30 connected to a firewall as its gateway
i configured an svi on vlan 30 to be able to manage it
i can reach its from within the subnet but not from outside
interface GigabitEthernet1/0/11
 switchport access vlan 30
 switchport mode access
 spanning-tree portfast
interface Vlan30
 ip address 172.30.100.5 255.255.255.0
Giuseppe Larosa
Hello @a.alyahia ,
on the L2 switch:
if IP routing is disabled you need to configure the firewall 's IP address as default gateway
ip default-gateway 172.30.100.1
if IP routing is enabled you need to configure a default static route pointing to the FW IP address
ip route 0.0.0.0 0.0.0.0 172.30.100.1
Likely the first option applies to your case.
Hope to help
Giuseppe
Reza Sharifi
Check the NAT config on the firewall. You maybe NATing 172.20.100.0/24 subnet only and not 172.30.100.0/24 subnet. If that is the case, add 172.30.100.0 subnet and try again.
Giuseppe Larosa
Hello @a.alyahia ,
on the L2 switch:
Hope to help
Giuseppe
a.alyahia
issue was a mistaken gateway ip
