L2 Trunk problem
supportFTS74691
Hello all,
I have installed a Cisco 9500 switch and a Firepower 2100 running ASA 9.8
The issue I am facing its the I am trying to connect the switch and firewall via L2  sub interfacesare not coming up on ay port that I have configured sub interfaces
FW
etrhernet1/4 description MAnagment WIFI Security VLAN71
vlan 71
nameif WIFI
security-level 50
Switch
interface TwentyFiveGigE1/0/24
description ** WIFI DMZ Uplink to Primary Firewall **
switchport
switchport trunk allowed vlan 70,71,78,90,98
switchport mode trunk
no cdp enable
Has any body had this issue before ?
marce1000
 - Just after you try a connection issue show logging on the 9500. Check if you can find any useful info's
 M.
I am seeing
0:47:10.500: %LINK-3-UPDOWN: Interface TwentyFiveGigE1/0/24, changed state to down
*Jul 11 10:47:13.845: %SYS-5-CONFIG_I: Configured from console by console
*Jul 11 10:49:35.150: %SYS-5-CONFIG_I: Configured from console by console
*Jul 11 10:49:55.379: %LINK-5-CHANGED: Interface TwentyFiveGigE1/0/24, changed state to administratively down
*Jul 11 10:49:57.812: %LINK-3-UPDOWN: Interface TwentyFiveGigE1/0/24, changed state to down
*Jul 11 10:49:57.852: %SYS-5-CONFIG_I: Configured from console by console
*Jul 11 10:53:41.191: %TRANSCEIVER-3-RPC_FAILED: R0/0: iomd: Application error rc = 6: -Traceback= 1#55d3b01750320abd4068e409012c6e09 errmsg:7F
F1A249F000+17D4 iomd_spa_infra:7FF1AE402000+6FE4A iomd_spa_infra:7FF1AE402000+52FDA iomd_spa_infra:7FF1AE402000+53D86 spa_ipc_shim:7FF192468000+4
8A5F if_combined_ngmod:7FF185B52000+146C52 if_combined_ngmod:7FF185B52000+146A40 :55568D407000+541CF evutil:7FF19EE46000+7776 evutil:7FF19EE46000
+75C5 evlib:7FF1A2ED8000+8942 evlib:7FF1A2ED8000+944C :55568D407000+5334D :55568D407000+53129 :55568D407000+BB
*Jul 11 11:03:41.278: %TRANSCEIVER-3-RPC_FAILED: R0/0: iomd: Application error rc = 6: -Traceback= 1#55d3b01750320abd4068e409012c6e09 errmsg:7F
*Jul 11 11:03:48.140: %SYS-5-CONFIG_I: Configured from console by console
Could be a bug. Check if software version is recent. M.
 (but as stated earlier , check software version too and look into possibilities of upgrading (e.g.)
 Ref :
 https://www.cisco.com/c/en/us/td/docs/ios/system/messages/guide/sm_cn11.pdf
           %TRANSCEIVER-3-RPC_FAILED: Application error rc = [dec]:
Explanation The system failed to retrieve the information required to execute the comand.
Recommended Action Copy the message exactly as it appears on the console or in the system log.
Enter the show version command to gather data that might help identify the nature of the message.
Research and attempt to resolve the issue using the tools and utilities provided at
http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying
information. Also perform a search of the Bug Toolkit
http://www.cisco.com/pcgi-bin/Support/Bugtool/home.pl. If you still require assistance, open a case
with the Technical Assistance Center via the Internet
http://tools.cisco.com/ServiceRequestTool/create, or contact your Cisco technical support
representative and provide the representative with the gathered information. Attach the following
information to your case in nonzipped, plain-text (.txt) format: the output of the show logging and
show tech-support commands and your pertinent troubleshooting logs.
