L2 Tunneling
Hi guys,
There is any way of passing two vlan through a l2 tunnel ? we are trying to setup and transport service for an ISP and we need to pass through the tunnel one admin vlan and one data vlan at the same time.
willwetherman
Yes this is possible using L2TPv3. Let me know if you need an example config
The example would be great.
Sure.
Please see attached example topology.
The goal is to allow the devices in Admin VLAN 11 and Data VLAN 12 to communicate with each other over the L3 link.
Simple explaination
The Admin and Data devices are members of their respective VLANs and the VLANs are being trunked by the switches to the router Gig0/2 interfaces. When the routers receive the dot1q tagged frames, it encapsulates them with a L2TPv3 header, inserts a new IP header and transports them over the WAN to the remote routers loopback address. The outer IP and L2TPv3 headers are then removed and the frame is sent out the Gig0/2 interface.
R1
l2tp-class class1
 authentication
 password 0 1234
pseudowire-class ethernet
 encapsulation l2tpv3
 protocol l2tpv3 class1
 ip local interface Loopback1
 ip pmtu
 ip dfbit set
interface loopback1
 ip address 192.168.0.1 255.255.255.255
interface GigabitEthernet0/1
 ip address 10.0.0.1 255.255.255.252
interface GigabitEthernet0/2
interface GigabitEthernet0/2.11
 encapsulation dot1Q 11
 xconnect 192.168.0.2 11 encapsulation l2tpv3 pw-class ethernet
interface GigabitEthernet0/2.12
 encapsulation dot1Q 12
 xconnect 192.168.0.2 12 encapsulation l2tpv3 pw-class ethernet
ip route 192.168.0.2 255.255.255.255 10.0.0.2
R2
l2tp-class class1
 authentication
 password 0 1234
 ip pmtu
 ip dfbit set
interface loopback1
 ip address 192.168.0.2 255.255.255.255
 ip address 10.0.0.2 255.255.255.252
 xconnect 192.168.0.1 11 encapsulation l2tpv3 pw-class ethernet
 xconnect 192.168.0.1 12 encapsulation l2tpv3 pw-class ethernet
ip route 192.168.0.1 255.255.255.255 10.0.0.1
Hope this helps
