L2TPv3 and Spanning-tree issue
jimmystorm9
Question:
We have a need to extend additional Vlans (separate broadcast segments) to a remote site; which using L2TPv3 works very well. However, we are having problems understanding why we cannot get Cisco spanning-tree MST 802.1s operational across the L2TPv3 topology. The switch command sh span mst reveals both SW1 and SW2 claim ROOT status.  Does anyone know for sure if MST over L2TPv3 does work and perhaps knows how to get it operational --OR-- MST over L2TPv3 does not work?  Also, is L2TPv3 an obsolete legacy technology and has been replaced by something more functional?
Topology in use: (see attached MS Paint topology; I couldn't get the pic to appears here)
What we know:
When using the routers physical interfaces (G0/0) to extend a single Vlan; spanning-tree MST 802.1s operates as expected eg. SW1 becomes the root as configured and SW2 is backup root.
When using the routers sub-interfaces (G0/0.1, G0/0.2 etc.) to extend multiple Vlans; spanning-tree MST 802.1s does  NOT operate as configured. Eg. Both SW1 and SW2 claim root status
Placing a hub between SW1 and L2tun-1; Wireshark shows spanning-tree MST, cdp, vtp etc. is being sent out SW1 F1/0/16 interface. Spanning-tree MST frames have the user configured name, revision # and Vlan instance parameters. I can post this output if someone thinks it will be useful in resolving this issue.
SW1# sh int trunk
Port        Mode             Encapsulation  Status        Native vlan
Fa1/0/16    on               802.1q         trunking      1
Port        Vlans allowed on trunk
Fa1/0/16    1-4094
Port        Vlans allowed and active in management domain
Fa1/0/16    1-3
Port        Vlans in spanning tree forwarding state and not pruned
Fa1/0/16    1-3
SW2# sh int trunk
Fa1/0/13    on               802.1q         trunking      1
Fa1/0/13    1-4094
Fa1/0/13    1-3
Fa1/0/13    1-3
SW1# sh cdp nei
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
L2Tun-1          Fas 1/0/16        127             R S I  2821      Gig 0/0.1
SW2              Fas 1/0/16        151             R S I  WS-C3750- Fas 1/0/13
SW2# sh cdp nei
L2Tun-2          Fas 1/0/13        155             R S I  2821      Gig 0/0.1
SW1              Fas 1/0/13        136             R S I  WS-C3750- Fas 1/0/16
SW1# sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.0.0.1                -   0013.8072.1a40  ARPA   Vlan1
Internet  10.0.0.2                2   000f.2325.a740  ARPA   Vlan1
Internet  192.168.2.1             -   0013.8072.1a46  ARPA   Vlan2
Internet  192.168.2.2            12   000f.2325.a748  ARPA   Vlan2
Internet  192.168.3.1             -   0013.8072.1a47  ARPA   Vlan3
Internet  192.168.3.2            12   000f.2325.a749  ARPA   Vlan3
SW2# sh arp
Internet  10.0.0.1                2   0013.8072.1a40  ARPA   Vlan1
Internet  10.0.0.2                -   000f.2325.a740  ARPA   Vlan1
Internet  192.168.2.1            12   0013.8072.1a46  ARPA   Vlan2
Internet  192.168.2.2             -   000f.2325.a748  ARPA   Vlan2
Internet  192.168.3.1            12   0013.8072.1a47  ARPA   Vlan3
Internet  192.168.3.2             -   000f.2325.a749  ARPA   Vlan3
SW1# sh span mst
##### MST0    vlans mapped:   1-800
Bridge        address 0013.8072.1a00  priority      4096  (4096 sysid 0)
Root          this switch for the CIST
Operational   hello time 2 , forward delay 15, max age 20, txholdcount 6
Configured    hello time 2 , forward delay 15, max age 20, max hops    20
Interface        Role Sts Cost      Prio.Nbr Type
Fa1/0/8          Desg FWD 200000    128.10   P2p
Fa1/0/10         Desg FWD 200000    128.12   P2p
Fa1/0/16         Desg FWD 200000    128.18   P2p
SW2# sh span mst
Bridge        address 000f.2325.a700  priority      61440 (61440 sysid 0)
Fa1/0/2          Desg FWD 200000    128.4    P2p
Fa1/0/13         Desg FWD 200000    128.15   P2p
SW1# sh ip int br | e do
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  10.0.0.1        YES manual up                    up
Vlan2                  192.168.2.1     YES manual up                    up
Vlan3                  192.168.3.1     YES manual up                    up
FastEthernet1/0/8      unassigned      YES unset  up                    up
FastEthernet1/0/10     unassigned      YES unset  up                    up
FastEthernet1/0/16     unassigned      YES unset  up                    up
SW2# sh ip int br | e do
Vlan1                  10.0.0.2        YES manual up                    up
Vlan2                  192.168.2.2     YES manual up                    up
Vlan3                  192.168.3.2     YES manual up                    up
FastEthernet1/0/2      unassigned      YES unset  up                    up
FastEthernet1/0/13     unassigned      YES unset  up                    up
SW1#ping 10.0.0.2
Sending 5, 100-byte ICMP Echos to 10.0.0.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/9 ms
SW1#ping 192.168.2.2
Sending 5, 100-byte ICMP Echos to 192.168.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/5/9 ms
SW1#ping 192.168.3.2
Sending 5, 100-byte ICMP Echos to 192.168.3.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/8 ms
SW2#ping 10.0.0.1
Sending 5, 100-byte ICMP Echos to 10.0.0.1, timeout is 2 seconds:
SW2#ping 192.168.2.1
Sending 5, 100-byte ICMP Echos to 192.168.2.1, timeout is 2 seconds:
SW2#ping 192.168.3.1
Sending 5, 100-byte ICMP Echos to 192.168.3.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/8 ms
L2Tun-1# sh xcon all
Legend:    XC ST=Xconnect State  S1=Segment1 State  S2=Segment2 State
  UP=Up       DN=Down            AD=Admin Down      IA=Inactive
  SB=Standby  RV=Recovering      NH=No Hardware
XC ST  Segment 1                         S1 Segment 2                         S2
UP     ac   Gi0/0.1:1(Eth VLAN)          UP l2tp 10.2.0.2:1                   UP
UP     ac   Gi0/0.2:2(Eth VLAN)          UP l2tp 10.2.0.2:2                   UP
UP     ac   Gi0/0.3:3(Eth VLAN)          UP l2tp 10.2.0.2:3                   UP
L2Tun-2# sh xcon all
UP     ac   Gi0/0.1:1(Eth VLAN)          UP l2tp 10.1.0.1:1                   UP
UP     ac   Gi0/0.2:2(Eth VLAN)          UP l2tp 10.1.0.1:2                   UP
UP     ac   Gi0/0.3:3(Eth VLAN)          UP l2tp 10.1.0.1:3                   UP
L2Tun-1# sh xconnect interface g0/0.1 det
            Interworking: none                   Session ID: 4114808408
                                                 Tunnel ID: 3813445228
                                                 Protocol State: UP
                                                 Remote Circuit State: UP
                                                 pw-class: NATIVE
L2Tun-2# sh xconnect interface g0/0.1 detail
            Interworking: none                   Session ID: 2454835785
                                                 Tunnel ID: 2658829555
                                                 Protocol State: UP
                                                 pw-class: NATIVE
hostname L2Tun-1
boot-start-marker
boot system flash:c2800nm-adventerprisek9-mz.151-4.M8.bin
boot-end-marker
no ip source-route
ip cef
no ip domain lookup
no ipv6 cef
l2tp-class MGT
 authentication
 hello 5
 password 7 062B2815
 cookie size 8
vtp domain R19
vtp mode transparent
pseudowire-class NATIVE
 encapsulation l2tpv3
 protocol l2tpv3 MGT
 ip local interface Loopback1
 ip pmtu
interface Loopback1
 ip address 10.1.0.1 255.255.255.255
interface GigabitEthernet0/0
 mtu 1600
 no ip address
interface GigabitEthernet0/0.1
 encapsulation dot1Q 1 native
 xconnect 10.2.0.2 1 pw-class NATIVE
interface GigabitEthernet0/0.2
 encapsulation dot1Q 2
 xconnect 10.2.0.2 2 pw-class NATIVE
interface GigabitEthernet0/0.3
 encapsulation dot1Q 3
 xconnect 10.2.0.2 3 pw-class NATIVE
interface GigabitEthernet0/1
 mtu 1600
 ip address 10.0.0.130 255.255.255.128
router ospf 1
 router-id 10.0.0.130
 network 10.0.0.0 0.255.255.255 area 0
 network 192.168.0.0 0.0.0.255 area 0
 network 192.192.192.1 0.0.0.0 area 0
hostname L2Tun-2
boot-start-marker
boot-end-marker
no ip source-route
ip cef
no ip domain lookup
no ipv6 cef
l2tp-class MGT
 authentication
 hello 5
 password 7 07220678
 cookie size 8
vtp domain R18
 protocol l2tpv3 MGT
 ip pmtu
interface Loopback1
 ip address 10.2.0.2 255.255.255.255
 mtu 1600
 no ip address
 xconnect 10.1.0.1 1 pw-class NATIVE
 xconnect 10.1.0.1 2 pw-class NATIVE
 xconnect 10.1.0.1 3 pw-class NATIVE
 mtu 1600
 ip address 10.0.0.129 255.255.255.128
router ospf 1
 router-id 10.0.0.129
fsebera
Level 4
Level 4
Hey Jimmy,
Sorry for the slow response but it took me a while to lab it up.
1st problem I see is you have duplicate IP addresses assigned, Vlan1 is using 10 space as-well-as your PE to cloud links. I guess since your frames are encapsulated on the PE links in L2TPv3 encapsulation this should not be an issue but it was a problem using your posted configurations in my lab setup.
Also, since all frames that egress SW1 (to PE) are tagged (each with its own Vlan ID) this is why all the protocols are functional except STP. Putting Wireshark on the wire, this is what the spanning-tree frames looks like, Notice no VLAN ID.
Frame 1: 135 bytes on wire (1080 bits), 135 bytes captured (1080 bits)
    Encapsulation type: Ethernet (1)
    Arrival Time: Jul 22, 2014 14:16:25.211808000 Eastern Daylight Time
    [Time shift for this packet: 0.000000000 seconds]
    Epoch Time: 1406052985.211808000 seconds
    [Time delta from previous captured frame: 0.000000000 seconds]
    [Time delta from previous displayed frame: 0.000000000 seconds]
    [Time since reference or first frame: 0.000000000 seconds]
    Frame Number: 1
    Frame Length: 135 bytes (1080 bits)
    Capture Length: 135 bytes (1080 bits)
    [Frame is marked: False]
    [Frame is ignored: False]
    [Protocols in frame: eth:llc:stp]
    [Coloring Rule Name: Broadcast]
    [Coloring Rule String: eth[0] & 1]
IEEE 802.3 Ethernet
    Destination: Spanning-tree-(for-bridges)_00 (01:80:c2:00:00:00)
        Address: Spanning-tree-(for-bridges)_00 (01:80:c2:00:00:00)
        .... ..0. .... .... .... .... = LG bit: Globally unique address (factory default)
        .... ...1 .... .... .... .... = IG bit: Group address (multicast/broadcast)
    Source: Cisco_72:1a:12 (00:13:80:72:1a:12)
        Address: Cisco_72:1a:12 (00:13:80:72:1a:12)
        .... ...0 .... .... .... .... = IG bit: Individual address (unicast)
    Length: 121
Logical-Link Control
    DSAP: Spanning Tree BPDU (0x42)
    IG Bit: Individual
    SSAP: Spanning Tree BPDU (0x42)
    CR Bit: Command
    Control field: U, func=UI (0x03)
        000. 00.. = Command: Unnumbered Information (0x00)
        .... ..11 = Frame type: Unnumbered frame (0x03)
Spanning Tree Protocol
    Protocol Identifier: Spanning Tree Protocol (0x0000)
    Protocol Version Identifier: Multiple Spanning Tree (3)
    BPDU Type: Rapid/Multiple Spanning Tree (0x02)
    BPDU flags: 0x7c (Agreement, Forwarding, Learning, Port Role: Designated)
        0... .... = Topology Change Acknowledgment: No
        .1.. .... = Agreement: Yes
        ..1. .... = Forwarding: Yes
        ...1 .... = Learning: Yes
        .... 11.. = Port Role: Designated (3)
        .... ..0. = Proposal: No
        .... ...0 = Topology Change: No
    Root Identifier: 32768 / 0 / 00:13:80:72:1a:00
        Root Bridge Priority: 32768
        Root Bridge System ID Extension: 0
        Root Bridge System ID: Cisco_72:1a:00 (00:13:80:72:1a:00)
    Root Path Cost: 0
    Bridge Identifier: 32768 / 0 / 00:13:80:72:1a:00
    Port identifier: 0x8012
    Message Age: 0
    Max Age: 20
    Hello Time: 2
    Forward Delay: 15
    Version 1 Length: 0
    Version 3 Length: 80
    MST Extension
        MST Config ID format selector: 0
        MST Config name: REGION1
        MST Config revision: 3
        MST Config digest: e13a80f11ed0856acd4ee3476941c73b
        CIST Internal Root Path Cost: 0
        CIST Bridge Identifier: 32768 / 0 / 00:13:80:72:1a:00
            CIST Bridge Priority: 32768
            CIST Bridge Identifier System ID Extension: 0
            CIST Bridge Identifier System ID: Cisco_72:1a:00 (00:13:80:72:1a:00)
        CIST Remaining hops: 20
        MSTID 1, Regional Root Identifier 24576 / 00:13:80:72:1a:00
            MSTI flags: 0x7c (Agreement, Forwarding, Learning, Port Role: Designated)
            MSTID 1, priority 24576 Root Identifier 00:13:80:72:1a:00
            Internal root path cost: 0
            Bridge Identifier Priority: 6
            Port identifier priority: 8
            Remaining hops: 20
Now, as far as getting STP frames to the other side, check out this doc!!!
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3550/software/release/12-1_13_ea1/configuration/guide/3550scg/swtunnel.html
Hope this works for you
Frank
