L3 issues between ASW and Nexus when a VPC is down
geeksy
Hope some can help and identify an issue I am facing. Below is my lab topology in GNS3, using nxsosv-9k-7.0.3.16.2 image.
ASW has links to NXS1 and NXS2 in a port channel. Everything works fine in the normal scenario, I can ping both NXS and HSRP. When I fail one of the link, from NXS1 to ASW, I cannot ping NXS2 or the HSRP IP but odd, I can ping NXS1. In the failure scenario, the only path for ASW is via NXS2, so unsure why I can't ping it but can ping NXS1 over vpc peer link.
Before the failure, MAC address table of ASW shows path for NXS1 & HSRP via Gi0/1. After the failure, it correctly updates the MAC table to Gi0/0 for all three IPs. So unsure what the issue and what I am doing wrong.
Any help is highly appreciated, all configs and outputs attached. Thanks in advance.
==========Ping ARP and MAC table on ASW==========
Switch#ping 192.168.1.2
Sending 5, 100-byte ICMP Echos to 192.168.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 10/11/14 ms
Switch#ping 192.168.1.3
Sending 5, 100-byte ICMP Echos to 192.168.1.3, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Switch#ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Switch#sh ip arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 192.168.1.1 2 0000.0c07.ac05 ARPA Vlan30
Internet 192.168.1.2 10 5005.0001.0007 ARPA Vlan30
Internet 192.168.1.3 10 5005.0002.0007 ARPA Vlan30
Internet 192.168.1.254 - 5005.0003.801e ARPA Vlan30
Switch#sh mac address-table
Mac Address Table
Vlan Mac Address Type Ports
30 0000.0c07.ac05 DYNAMIC Gi0/0
30 5005.0001.0007 DYNAMIC Gi0/0
30 5005.0002.0007 DYNAMIC Gi0/0
Total Mac Addresses for this criterion: 3
Switch#
geeksy
Issue resolved.
Since this was GNS3 lab, even though NXS1 interface to ASW is shutdown, ASW still has its interface up. I shut the Gi1 on ASW and everything works fine as expected. Not entirely sure why it didn't work in the first place even though MAC table appears correct though.
