L3 or L2 connectivity between Data Centers
Greetings,
We have a dark fiber between data centers. Do you recommend set it as L3 link or L2 trunk to have stretched VLANs.
EZ.
Reza Sharifi
If you want to extend vlans, the connection should be layer-2. If you have separate vlans per data center, you can use L3.
Reza Sharifi
Oleg Volkov
Hi.
You can use L3 and VXLAN overlay for L2.
Because if You will use classic L2 You can have trouble with suboptimal traffic and many more problem.
Read about VXLAN and distributed gateways.
Helping seriously ill children, all together. All information about this, is posted on my blog
Sounds a good idea. I will read about VXLAN more.
