L3 Routing
rsabapathee
Lads,
Follows the instruction to implement L3 routing below:
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008019e74e.shtml
However, the part where I have to alter one switch port to a routed port is causing problems. As soon as I do that I cannot access the network connected to the router.
However if I connect the router to the switch on a dot1q trunk port, then everything works fine.
I have configured VLAN1 with an ip address and issued ip route commands to the Router.
Can someone clarify?
glen.grant
If you are using the vlan 1 SVI for the ip address then your connecting port would be a switchport not a routed port . If you want to use the actual port as a routed port then get rid of the int vlan 1 ip address and put that on the routed port (no switchport) that you configure .
