L3 Switch CPU High
Sakthi vel
Dear All,
Our one of the Core switch CPU frequently getting High, Kindly let us know what is the cause for this.
Attached is the Logs
Sakthi vel
System restarted at 09:56:14 asia Sun Nov 7 2010
System image file is "bootflash:/cat4500-ipbasek9-mz.122-44.SG1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C4506 (MPC8245) processor (revision 7) with 524288K bytes of memory.
Processor board ID FOX113706U3
MPC8245 CPU at 400Mhz, Supervisor V
Last reset from PowerUp
8 Virtual Ethernet interfaces
242 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
See the troubleshooting steps below
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-4000-series-switches/65591-cat4500-high-cpu.html
 The show processes cpu output shows that there are two processes that use the CPU— Cat4k Mgmt HiPri and Cat4k Mgmt LoPri . These two processes aggregate multiple platform-specific processes which perform the essential management functions on the Catalyst 4500. These processes process control plane as well as data packets that need to be software-switched or processed.
In order to see which of the platform-specific processes use the CPU under the context of Cat4k Mgmt HiPri and Cat4k Mgmt LoPri , issue the show platform health command and check what is the process exceeding the target, once that has been identify you can move forward.
Leo
