- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-01-2011 06:08 AM - edited 03-06-2019 03:17 PM
I have a basic problem with my level 3 switch.
Below you'll find a drawing which is worth more than a thousand words:
Let's say that hosts on the LAN (below) are sending syslog messages to the syslog server.
The switch is configured as shown above: The VLAN 100 is associated to the physical interface to the LAN 10.0.0.0/24. So when showing the routing table of the switch, we see that the network 10.0.0.0/24 is directly connected to the interface.
Let's assume that the interface on the switch (with the vlan 100) is down, the routing table does not contain the network 10.0.0.0/24 anymore so all syslog messages are taking the default route to the firewall. But the firewall is not supposed to get these packets and drop them. The trick is that the firewall itself is sending messages which will then be re-routed to itself by the switch, and so on, indefinitely!!
How am I supposed to solve this? Is it possible to configure the switch so that the packets are dropped if the interface is down and does not take the default route? Using ACLs would be a solution but this is a network issue, not a security one?
Do you have any idea?
Thanks in advance!
Solved! Go to Solution.
- Labels:
Other Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-01-2011 06:44 AM
You can add a static route for the 10.0.0.0/24 network as follows:
ip route 10.0.0.0 255.0.0.0 Null0
This route will have a AD of 1; so as long as your connected route is present (AD=0), it will be used. As soon as connected route goes off, static route will be used and packets will get dropped.
Another option is to configure a regular static route and use 'permanent' keyword after the route so it does not get flushed out in case next hop is unreachable.
ip route 10.0.0.0 255.0.0.0 gix/y permanent
ip route 10.0.0.0 255.0.0.0 next hop ip permanent
Hope this helps,
Shashank
P.S. Please rate the helpful post
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-01-2011 06:44 AM
Hope this helps,
Shashank
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-01-2011 07:16 AM
Great, thanks!
