L3 switch intervlan routing
srikanth ath
Level 4
Level 4
Quick suggestion
I have L3 switch cisco 3750
i have configured two vlans assigned ports to it
. when i connected PCs to two ports of different VLAN , lets say PC1 in vlan 30 i can ping to different vlan ip gateway i.e 10.10.17.1 but couldnt ping  to the PC connected to vlan 40 (PC 2 10.10.17.2)
i know this is intervlan routing , but couldnt find a solution for this .. can any one of you sugest
i have enabled IProuitng
#sh ip route
     10.0.0.0/24 is subnetted, 3 subnets
C       10.0.1.0 is directly connected, GigabitEthernet1/0/12
C       10.10.17.0 is directly connected, Vlan40
C       10.10.16.0 is directly connected, Vlan30
VLANS:
interface Vlan30
description development
ip address 10.10.16.1 255.255.255.0
interface Vlan40
description vlan for product
ip address 10.10.17.1 255.255.255.0
can any one please explain me whats the problem with configuration changes
thanks Srikanth
p
Jon Marshall
Srikanth
If you can ping the other PC's default-gateway then it sounds like the 3750 is setup correctly.
Check your PC's for firewalls that could be blocking the ping requests either Windows firewall or possibly AV software.
Jon
I turned off the firewall . even then i couldnt ping
any suggestions , got to do this by 1 hour to set up in company..where everything went fine and at last this is the issue. we are getting
Srikanth
Srikanth
From PC in vlan 30 can you ping vlan 40 vlan interface IP ?
From PC in vlan 40 can you ping vlan 30 vlan interface IP ?
If no to either then -
1) check default-gateway and subnet mask on each PC
2) check the ports the PCs are connected into are set to the right vlan
if yes to both then -
from switch can you ping PC in vlan 30 and vlan 40
if no then recheck PCs
Jon
Hi Srikanth,
If you are able to ping the vlan gw from other vlan then the L3 inter vlan routing is fine.
Make sure the pc is configured with correct IP and DG from which you are trying to ping other vlan pc's
Please rate the helpful posts.
Naidu.
