L3 Switches behavior
bongskiie
So, we have this amateur kind of setup in school:
• DHCP Server in a Private DMZ that is connected to an ASA Firewall
• ASA Firewall has subinterface for the network 172.240.30.0/24, .1 is the GW.
• That network consists of 2 units of Layer 3 switches, namely, Switch 1 and Switch 2, both are ACCESS layer switches.
• DHCP pool was enabled in Switch 1.
• This setup is working fine.
Scenario:
• We are trying to migrate the DHCP pool in Switch 1 to our DHCP Server located in our Private DMZ.
• First, we failed to migrate it, although IP helper was configured in the switch's data VLAN and DHCP pool was deleted already in Switch 1 until our mentor told us that we have to configure IP routing in Switch 1.
• All went well for those devices directly connected to Switch 1, but not for Switch 2.
• And then I went and tried to configure IP helper as well in the same data VLAN we configured in Switch 1 to Switch 2, and it worked.
After that, I'm thinking why would it behave like that, and was assuming that the Switch 1 became Layer 3 device so that it wouldn't take any broadcast from any hosts (DHCP Discover) unless it was unicast/multicast. Thus IP helper will solve the problem.
Question is, is it normal for layer 3 switches to behave that way? I mean, it also possesses layer 2 functionalities still while having capabilities of layer 3 right? May I know your insights?
Also, are there any other much better setup than we did in our migration? :)
Thank you and hoping for your immediate response!
Hi bongskiie,
Answer:- Yes it is the normal behavior. After migration, your data network and DHCP server are in different networks. You defined the helper address, now switch must have to know about how to reach that (DHCP server) network i.e you must have to define routes for that network or simply a default route.
Question:- Also, are there any other much better setup than we did in our migration?
Answer:- You can define ASA as DHCP relay agent and leave the switches to act as layer 2 switches.
If this is helpful please give a thumbs up. :-)
Spooster IT Services Team
