i have a stupid question
i have a 3750 in the stack and other 3750 stack (connect over wan, there are not possible connect over LACP or FlexLink) and extreme switch connect over LACP
But i don't now how must be configuration STP on the LACP link between server and extreme switch.
I have loop only between two 3750 stack.
LACP for servers (not trunk)
- there are must be spanning tree portfast or not? (on picture number 3.)
what the correct settings i think that is possible shutdown LACP fort these ports, because LACP is single cable.
interface Port-channel11
description ***Cluster vvcn01***
switchport access vlan 10
spanning-tree portfast
interface GigabitEthernet1/0/23
description ***Team 01lan***
channel-group 11 mode active
interface GigabitEthernet2/0/23
description ***LAN***
is it possible shutdown STP fort these ports? or what the correct settings for ports connect over LACP to the SERVER.
LACP with TRUNK between extreme switch (on picture number 1. and 2.)
- what the correct settings i think that is possible shutdown LACP fort these ports, because LACP is single cable.
interface Port-channel3
description ***Trunk to vvlansw01***
switchport mode trunk
interface GigabitEthernet1/0/4
channel-group 3 mode active
interface GigabitEthernet2/0/4
TRUNK between c3750 (on picture number 4.)
- here must be STP, because other switch is over wan
interface Port-channel28
description ***Propoj do TP***
interface GigabitEthernet1/0/10
description ***Trunk to TP**
interface GigabitEthernet2/0/10
description ***Trunk to TP***
