LACP Implementation with HP servers and CISCO
Tbaror123
Hello ,
I need to implement LACP HP servers mostly DL 380 g7 with Intel based dual port with two types of Cisco equipment
  1. first scenario server connected to 3750x stack of 4 switch's .
  2. second scenario same server type connected to two Cisco Nexsus 5596 .
My question regarding two type of connection
  • Is it possible to do active active ?
  • Would it give fault tolerance ?
  • With HP LACP implementation is there known issue or should i expect latency with such configuration?
  • What is the maximal lag- channel group that is possible per type?
how
Please advise
acampbell
For the 3750X have a look at the config guides.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_53_se/configuration/guide/swethchl.html#wp1275535
Alex
Regards, Alex. Please rate useful posts.
