LAN BASE ON 3560X
IngGerardo013
Hello People,
Just a simple questions,
why Cisco make 3560x switches with Lan Base(no routing functions)?
-What happen if I load an Image  L3, previously downloaded?    my device lost the warranty? or it doesn matter?
thank you guys!
Reza Sharifi
because some prople don't need layer-3 functionalities.  They want to use the switch as a layer-2 device only
If you purchase a 3560X with Lan Base software, and you decided later that you need all layer-3 functionalist, you need to purchase a layer-3 license and install it on your device.  It is called IP Services licence.
Reza Sharifi
