LAN Base to IP Base
mark.carroll
i upgradeed an image on 3750 from Lan base to IP base, it worked fine. howver im just wondering if there any licensing implications, did the upgrade a few weeks ago, would the switches still work on a temp license somehow? how can I verify if there is a licensing issue ?
thanks
Ivan Shirshin
You can use "show version" (to check active  license) and "show license" (to check installed licenses) commands, e.g.
SW# show version
Switch 01
License Level                   : advipservices
License Type                    : Permanent
Next reboot licensing Level     : advipservices
SW# show license
License Store: Primary License Storage
StoreIndex: 0   Feature: advipservices
        License Type: Permanent
        License State: Active, In Use
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Cisco-Workshop#sh license file switch 1
  Store Index: 0
    License: 11 lanbase 1.0 LONG NORMAL STANDALONE EXCL INFINITE_KEYS INFINITE
             _KEYS NEVER NEVER NiL SLM_CODE CL_ND_LCK NiL *1PDZN2338RUDDM5400
             NiL NiL NiL 5_MINS WS-C3750X-24P-LFDO1635Z1YH
             dy3xikdn6845lOZaGCZZf0lPfOpWrdqnZxpDxF7zcALJnBleUOL9k
             HgXVImvQWqYLNIbggBXTBuB0sveVgwoRm3so9Fb,ecXUC2Kt7JMuetjLAIhALHkRy
             ERuf,AYD1hygfr$AQEBIf8B//9LgxgiGKqgU+tQJtbPT9m+ZSEU1HWNQZgRz
             WP8Kh6epTNN5wAtDUlLM7OlGJBKbBd6Ow7IDhk2dhR/JE9FZwy//ZYWf7Rt365yZ7
             L3QSEE4IwFaYxUFTifB8Vzdej0Wq/ZWFQCNeZ3AAn/e+/utIJL+sfQaD8XcLdJxvc
             D/8AmvxHj3gPTnheE9B5vKxVlY7c=
    Comment:
       Hash: 2R6XqqT/z+D3VDzEWL2NfoBFgs8=
License Store: Evaluation License Storage
Cisco-Workshop#
