LAN Broadcasting
arifspectrum
How to check that which ports of a switch are affected to broadcast and is there any tool available to capture/find out the broadcast traffic? plz help
Kevin Dorrell
Level 10
Level 10
If you do a "show int", it will tell you the number of broadcasts transmitted on each interface.  I find the best way to examine the broadcasts is to connect WireShark or snoop to an unused port.  Broadcasts, by definition, are sent to all ports on the VLAN.
Kevin Dorrell
Luxembourg
Thnaks for your reply.
Show Interface command output
GigabitEthernet1/0/5 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 5057.a835.1305 (bia 5057.a835.1305)
  Description: "Admin-Bld_2-Access connection"
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:17, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1087000 bits/sec, 128 packets/sec
  5 minute output rate 261000 bits/sec, 171 packets/sec
     30618912 packets input, 36910343707 bytes, 0 no buffer
     Received 87486 broadcasts (61433 multicasts)
     0 watchdog, 61433 multicast, 0 pause input
     39848450 packets output, 4996613567 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Here I found 87468 broadcast packets on this interface. my question is for what value I can say that this interface is affected by broadcast?
They are all broadcasts.  The counter is cumulative, so you should take two reading spaced by, let us say, one hour, and calculate the difference.  That is the number of broadcasts the port has received.  What is a reasonable value?  It depends on what the port is used for.  My worst VLAN is running at about 20 broadcasts per second average.
Another useful form of the command is show interface count or show interface G1/0/5 count.  That presents the information in tabular form, and gives more detail.  There are other keywords you can add to give you more specific counters.
Kevin Dorrell
Luxembourg
