Lan -> ASA 5510 -> Router 1841 NAT Overload
johan.gonzalez
Greetings, this is my scenario:
LAN: a B class net
ASA 5510
Router 1841 with 2 ISP in each Fast Ethernet ports and outside port of asa connected to Fa0/0/0 (i have a 4 port Fast Ethernet attached to router)
My LAN its connected to inside port of ASA, and outside to router.
I need to connect my lan to internet, i tried to make the nat in the asa but i don't have connection.
This is the configuration of my asa and router:
ROUTER
interface FastEthernet0/0
description CANTV
ip address 200.11.x.x 255.255.255.248
duplex auto
speed auto
interface FastEthernet0/1
description MOVISTAR
ip address 186.24.x.x 255.255.255.248
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/0/0
description ASA_OUTSIDE
interface Vlan1
description GATEWAY ASA
ip address 192.168.200.1 255.255.255.252
ip route 0.0.0.0 0.0.0.0 186.24.X.X
no ip http server
no ip http secure-server
control-plane
end
ASA
: Saved
ASA Version 8.2(1)
interface Ethernet0/0
description Hacia Router Borde RBIAIM01
duplex full
nameif outside
security-level 0
ip address 192.168.200.2 255.255.255.252
interface Ethernet0/1
description Default Gateway LAN IAIM
nameif inside
security-level 100
ip address 150.140.x.1 255.255.0.0
interface Ethernet0/2
shutdown
nameif SinUso
no ip address
interface Ethernet0/3
shutdown
nameif SinUso2
no ip address
interface Management0/0
nameif management
security-level 100
ip address 192.168.2.1 255.255.255.0
management-only
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu WIFISOON 1500
mtu SinUso 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any inside
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 192.168.200.1 netmask 255.255.255.252
nat (inside) 1 0.0.0.0 0.0.0.0 dns
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 192.168.200.1 1
route inside 150.140.0.0 255.255.0.0 192.168.20.2 1
timeout xlate 3:00:00
: end
Can anybody help me?
justinmitchell
Level 4
Level 4
You need to change your global NAT on the ASA from the IP 192.168.200.1 to interface. That IP address is a duplicate of the router VLAN interface IP address.
global (outside) 1 interface
