LAN Problem
ahmad_ellahi
Community Member
Hello experts i have a CISCO old series router of 2500 series the problem which i am facing that this router have no LAN port by default and also do not provide support for modules so please tell me how can i attach my LAN to this router. router has 2 serial ports AUX port and a console port please help me. thanks
Waiting for reply
Best Regards
Ahmad Ellahi
7 Replies 7
Yudong Wu
Level 11
Level 11
sorry, you can not.
Maybe you should buy a new router.
Peter010101
Level 4
Level 4
You can not.
The best you can do is connect one of the serials to another router with a lan port.
ohassairi
Level 9
Level 9
it's stange to find a router without a lan interface.
has it an AUI port? this a lan interface.
if yes, then you can buy a converter AUI/RJ45
sudhendutaklikar
Community Member
you do one thing u buy a transreceiver which convert serial interface to RJ45 Female connector using this you can connect 1 Lan connection to your router
regard
sudhendu taklikar
system admin
