Lan to internet conection
Hello everyone,
First of all sorry for my english, i'll probably will make some grammar mistakes, but i think we could understand
I'm newbie with cisco routers (I have only done The CCNA-1 and 2) And I'm having some troubles when I want to connect my router 881W to my ADSL and give internet to my lan.
By the moment this is my configuration:
version 15.2
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip cef
no ipv6 cef
license udi pid CISCO881W-GN-E-K9 sn FCZ1617C502
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address dhcp
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
shutdown
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.1 254
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
login
transport input all
end
I just want to have internet connection from the Fast Ethernet 0 to 3. Right know I only have internet from the Fast Ethernet 4 (The Wlan) pinging from the router to outside.
Thanks for all.
2 Accepted Solutions
cadet alain
Supposing the fa4 is connected to a modem/router and that you only want as of now only wired machines in your LAN to access the internet:
no ip dhcp conflict
ip dhcp pool LAN_POOL
network 192.168.2.0 /24
default-router 192.168.2.254
dns-server 8.8.8.8
access-list 1 permit 192.168.2.0 0.0.0.255
ip nat inside source list 1 interface fa4
int vlan 1
ip address 192.168.2.254 255.255.255.0
ip nat inside
int fa4
ip nat outside
Alain
the values you provided  supposing a mask of 255.255.255.0 are not valid ip addresses but network addresses.
What do you want to do exactly? give the same IP everytime to same device with DHCP or have some devices with a ststic IP  ?
Also the default-gateway is a machine in the same subnet as the hosts so if your machines are in the 192.168.2.0/24 your default-gateway must be in the same subnet and it is the ip address of the corresponding vlan interface on the router.
Alain
cadet alain
no ip dhcp conflict
dns-server 8.8.8.8
int vlan 1
ip nat inside
int fa4
ip nat outside
Alain
Rate it with the maximum value!
A lot of thanks, it works
But now I have a problem,
If I want to have fixed ip in my Lan for example:
-network 192.168.3.0
-network 192.168.4.0
-network 192.168.25.0
What i need to do?
I have to specify the default gateway as the 192.168.2.254?
Thanks!
Alain
I got confused and I though that I would have some kind of problem with different LANs, but this LANs are concected to a Zentyal server, and Zentyal server to Cisco, so, It doesn't matter because they go to the cisco router as the Zentyal IP.
I tested and everything works fine.
A lot of thanks.
