LAN
vaishkhan161190
can anyone tell me that, i have 15-20 PC that connected to same LAN.
but in only  one and two PC's, I am getting ping 8.8.8.8 and Gateway but not getting ping www.google.com and www.yahoo.com, why?
and internet is working fine in this PC's.
Mark Malone
If you can ping the ip but not the name 9 times out iof 10 your DNS is not set right
Is the DHCP pool on the switch/router is there DNS settings set like below
Central Router
!do not assign this range to DHCP clients
ip dhcp-excluded address 10.0.0.1 10.0.0.5
ip dhcp pool central
! Specifies network number and mask for DHCP clients
 network 10.0.0.0 255.255.255.0
! Specifes the domain name for the client
 domain-name central
! Specifies DNS server that will respond to DHCP clients when they need to correlate host
! name to ip address
 dns-server 10.0.0.2
!Specifies the NETBIOS WINS server
 netbios-name-server 10.0.0.2
devils_advocate
Level 7
Level 7
As Mark has said, it sounds like a DNS issue if you are experiencing issues pinging hostnames and not IP addresses.
Try running and 'nslookup' within a command window and see what the results are when looking up a hostname.
