Latency Problem for ESX Hosts UCS Platform.
UniWAQ
Hello Guys,
I am facing latency problem for ESX hosts, anyone has idea to rectifiy it.
Ethernet15/12/22 is up
  Hardware: 1000/10000 Ethernet, address: 5006.0411.4843 (bia 5006.0411.4843)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is on
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 16week(s) 3day(s)
  30 seconds input rate 1126320 bits/sec, 318 packets/sec
  30 seconds output rate 2227304 bits/sec, 715 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 1.45 Mbps, 384 pps; output rate 2.32 Mbps, 719 pps
  RX
    220815413509 unicast packets  1285537280 multicast packets  40332691 broadcast packets
    222141724600 input packets  138608720572686 bytes
    43859579171 jumbo packets  0 storm suppression bytes
    0 runts  0 giants 0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun 0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    281030844760 unicast packets  2796723307 multicast packets  1967342830 broadcast packets
    285795009869 output packets  260169012740238 bytes
    136894895271 jumbo packets
    98972 output errors  0 collision  0 deferred 0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
  189550696 Tx pause
  70 interface resets
##CONFIG
interface Ethernet15/12/22
  switchport mode trunk
  switchport trunk allowed vlan 1001-1002,1281-1285,4050,4052-4055
spanning-tree port type edge trunk
  spanning-tree bpdufilter disable
  vpc orphan-port suspend
Reza Sharifi
What model of FEX are you using?
Also, can you explain the setup?
