Switch work, but not ping.
snurdygin
Network topology - router 3845 connect to the root switch Catalyst 5500 (CatOS), which is connected to the distribution switches 3508 and access switches 3524.
After a weekend half of 3524  is missing on 3 layer (cant ping), but  the switches work properly and can be seen themselves
with cdp.
IP addresses are registered in the 1 vlan and the most strange thing is that MAC address in this vlan are visible at 5500, and are visible in the arp table of the router (after "clear arp" they appear), but switches do not ping.
Initially it was suspected that there is a loop (stp has been disabled), and after I turn it on for the 1 vlan on one of the switches, and restart it, switch  appeared, but after some time fell off again. Even I thought it may be a problem with vtp, but when I look at the problem switch vtp status, I did not see any problems.
Config with altered ip addresses is in the attachment, and sorry for bad english.
khishtandar
hi
you must have at least one active port in vlan 1.
send "show ip int brief " of your switches .
pouya khishtandar
As I know, if in my vlan is allowed in trunk and there is interface vlan with ip, it should work.
Interface brief:
VLAN1 192.168.1.24 YES NVRAM up up
FastEthernet0/1 unassigned YES unset administratively down down
FastEthernet0/2 unassigned YES unset up up
FastEthernet0/3 unassigned YES unset up up
FastEthernet0/4 unassigned YES unset up up
FastEthernet0/5 unassigned YES unset down down
FastEthernet0/6 unassigned YES unset up up
FastEthernet0/7 unassigned YES unset administratively down down
FastEthernet0/8 unassigned YES unset down down
FastEthernet0/9 unassigned YES unset down down
FastEthernet0/10 unassigned YES unset administratively down down
FastEthernet0/11 unassigned YES unset down down
FastEthernet0/12 unassigned YES unset down down
FastEthernet0/13 unassigned YES unset down down
FastEthernet0/14 unassigned YES unset down down
FastEthernet0/15 unassigned YES unset down down
FastEthernet0/16 unassigned YES unset down down
FastEthernet0/17 unassigned YES unset down down
FastEthernet0/18 unassigned YES unset down down
FastEthernet0/19 unassigned YES unset down down
FastEthernet0/20 unassigned YES unset down down
FastEthernet0/21 unassigned YES unset down down
FastEthernet0/22 unassigned YES unset down down
FastEthernet0/23 unassigned YES unset down down
FastEthernet0/24 unassigned YES unset down down
GigabitEthernet0/1 unassigned YES unset down down
GigabitEthernet0/2 unassigned YES unset up up
Interfaces status:
Fa0/1 broken disabled 1 Half Auto 100BaseTX/FX
Fa0/2 connected 116 A-Full A-100 100BaseTX/FX
Fa0/3 connected 8 A-Full A-100 100BaseTX/FX
Fa0/4 connected 22 A-Full A-100 100BaseTX/FX
Fa0/5 notconnect 10 Half Auto 100BaseTX/FX
Fa0/6 connected 99 A-Full A-100 100BaseTX/FX
Fa0/7 disabled 119 Half Auto 100BaseTX/FX
Fa0/8 notconnect 1001 Auto Auto 100BaseTX/FX
Fa0/9 notconnect 1001 Auto Auto 100BaseTX/FX
Fa0/10 disabled 1001 Auto Auto 100BaseTX/FX
Fa0/11 notconnect 1001 Auto Auto 100BaseTX/FX
Fa0/12 notconnect 1001 Auto Auto 100BaseTX/FX
Fa0/13 notconnect 1001 Auto Auto 100BaseTX/FX
Fa0/14 notconnect 1001 Auto Auto 100BaseTX/FX
Fa0/15 notconnect 1001 Auto Auto 100BaseTX/FX
Fa0/16 notconnect 1001 Auto Auto 100BaseTX/FX
Fa0/17 notconnect 1001 Auto Auto 100BaseTX/FX
Fa0/18 notconnect 1001 Auto Auto 100BaseTX/FX
Fa0/19 notconnect 1001 Auto Auto 100BaseTX/FX
Fa0/20 notconnect 1001 Auto Auto 100BaseTX/FX
Fa0/21 notconnect 1001 Auto Auto 100BaseTX/FX
Fa0/22 notconnect 1001 Auto Auto 100BaseTX/FX
Fa0/23 notconnect 1001 Auto Auto 100BaseTX/FX
Fa0/24 notconnect 900 Auto Auto 100BaseTX/FX
Gi0/1 notconnect 1 Auto 1000 Missing
Gi0/2 connected trunk A-Full 1000 1000BaseLX
