Layer-2 Network
Arjun Dabol
its a very basic switching doubt.
can someone help me understand what is the meaning when we say ..... " its just a layer-2 network " ...?  Because today's network have IP address configured on all the devices so why we still say Layer-2 network.
switch-B  (ip address)
Switch - A (ip address)
Hosts (ip address)
Julio E. Moisa
Layer 2 networks use the MAC addresses to send data on a local area on a switch, Now there are switches multi layer, they can work on layer 2 and layer 3 at the same time. A layer 2 network is built by layer 2 switches or bridges only.
The layer 2 switches can have a management IP but they are unable to run routing tasks by themselves, a layer 3 devices is required for routing.
Hope it is useful.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Joseph W. Doherty
An IP address on a L2 switch, as also noted by Julio, is for management of the switch.  I.e. it's basically just another host IP, where in this case, the host is a L2 switch.
For " its just a layer-2 network " would imply the network does not use any L3 routing.  Your hosts, on a L2 only network, should also work with Ethernet hubs and/or dumb/non-management switches.
To look at this question from a slightly different perspective let us start from a fundamental concept:
a layer 2 network does forwarding using layer 2 MAC addresses.
a layer 3 network does forwarding using layer 3 IP addresses.
With that is mind I would say that the answer to the original post is that when you say it is just a layer 2 network then you are saying that it is a network that forwards traffic using the MAC address and ignoring the IP address. So functionally in this network all devices are in the same IP network.
Rick
Rick
