Layer 3 Module problem in Catalyst 4507R
Mansoor Hafeez
Greetings
I have installed new Cisco Catalyst 4507R Switch with Redundant Supervisor Engines IIPlus.
Before that I had the Cisco Catalyst Switch 4006 which was running the CatOS along with three modules installed which are as follows:
1. WS-X4232-L3
2. WS-X4424-GB-RJ45
3. WS-X4424-GB-RJ45
After insertion of these modules into the Switch 4507R, the modules WS-X4424-GB-RJ45 are dtected successfully and working fine but for the module WS-X4232-L3 is detected as unsupported module.
Do I need to perform some special configuration or i am missing something?
The sh version and sh module is as follows:
sh version
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(25)EW, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by Cisco Systems, Inc.
Compiled Fri 10-Dec-04 14:26 by kellythw
ROM: 12.2(20r)EW1
Dagobah Revision 95, Swamp Revision 3
Switch uptime is 3 minutes
Uptime for this control processor is 3 minutes
System image file is "bootflash:"
cisco WS-C4507R (MPC8245) processor (revision 4) with 262144K bytes of memory.
Processor board ID FOX0904030G
MPC8245 CPU at 266Mhz, Supervisor II+
Last reset from PowerUp
1 Virtual Ethernet interface
4 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
--More--
Switch#sh mod
Switch#sh module
Chassis Type : WS-C4507R
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 2 Supervisor II+ 1000BaseX (GBIC) WS-X4013+ JAE09065PYB
2 2 Supervisor II+ 1000BaseX (GBIC) WS-X4013+ JAE11097CH7
7 0 Unsupported module WS-X4232-L3 JAB06250839
M MAC addresses Hw Fw Sw Status
1 0013.c315.3f80 to 0013.c315.3f81 3.1 12.2(20r)EW1 12.2(25)EW Ok
2 0013.c315.3f82 to 0013.c315.3f83 4.3 12.2(20r)EW1 12.2(25)EWA8, Ok
7 0008.e3cd.78e0 to 0008.e3cd.7901 1.9 Unsupport
Mod Redundancy role Redundancy mode Redundancy status
1 Active Supervisor RPR Active
2 Standby Supervisor RPR Standby cold
Switch#
Jon Marshall
I don't think this card is supported by the Supervisor Engine IIPlus.
Attached is the data sheet for the Sup II Plus. Scroll down to supported modules. The WS-X4232-L3 is not on the list.
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a0080197424.html
Jon
ankbhasi
Hi Mansoor,
You already have sup 2+ which has routing capability so you do not need to have 4232 L3 blade in the chassis. So this blade will not work when you have sup 2+ in the chassis.
Ankur
Jon Marshall
Jon
According to the Datasheet there are two entries related to 4232 which are
? WS-X4232-GB-R-Cisco Catalyst 4500 32-Port 10/100 RJ-45), 2 Gigabit Ethernet (GBIC) module
? WS-X4232-RJ-XX-Cisco Catalyst 4500 32-Port 10/100 Module (RJ-45), plus modular uplink slot
In the second entry what is meaning of 'XX'
Mansoor
