Layer 3 port channel between sites connected over dark fiber
rudranetra
                   Has anyone configured Layer 3 port channel on Cisco 6509 switches which are connected over dark fiber between two buildings?
                   Is it possible?  please let me know.
Reza Sharifi
Yes, defiantly possible.  As long as all physical links have the same speed and duplex.
jitendra gupta
hi.
I agree with reza sharifi. if we use port channel on any switch  then each links in port channel have same spped and duplex.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Dark fiber - between buildings - don't recall if I've done that, but have done L3 port-channels across fiber between 6500s.  So, yes it should be possible.
This is my running configuration:
device: 2921-K9
c2921#sh run
Building configuration...
Current configuration : 2537 bytes
! Last configuration change at 07:33:17 UTC Wed Oct 30 2013
version 15.0
hostname c2921
boot-start-marker
boot system flash:c2900-universalk9-mz.SSA.portchannel
boot-end-marker
logging buffered 10000000
no logging console
no aaa new-model
no ipv6 cef
ip source-route
ip cef
voice-card 0
license udi pid CISCO2921/K9 sn FTX1411AM28
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
class-map match-all cust
match access-group 100
class-map match-all devclass
match  dscp af11
class-map match-all devclass1
match  dscp cs4
class-map match-all dev1
match access-group 151
class-map match-all RTP
match access-group 101
class-map match-all cdscp
match  dscp cs4
class-map match-all cdestip
match access-group 190
policy-map devp1
class devclass
  set dscp 45
policy-map pdev1
class dev1
  set dscp 45
policy-map cus
class cust
    priority 3000
policy-map RTP_1
class class-default
    bandwidth 9000
  service-policy cus
policy-map RTP
class RTP
    priority 3000
policy-map kumar
class cust
    bandwidth 1000
   police cir 1000000
policy-map pdestip
class cdestip
  set dscp ef
policy-map pdscp
class cdscp
  set dscp ef
policy-map devpolicy
class devclass
  set dscp ef
class devclass1
  set dscp ef
interface Port-channel1
ip address 10.1.1.1 255.255.255.0
load-interval 30
interface GigabitEthernet0/0
no ip address
load-interval 30
duplex auto
speed 10
channel-group 1
service-policy output pdestip
interface GigabitEthernet0/1
no ip address
load-interval 30
duplex auto
speed auto
interface GigabitEthernet0/2
load-interval 30
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.201.178.193 254
access-list 1 permit 192.168.1.254
access-list 2 permit 10.1.1.2
access-list 100 permit ip any host 10.1.1.2
access-list 101 permit udp any any range 10000 20000
access-list 101 permit icmp any any
access-list 151 permit ip 0.1.1.2 255.0.0.0 any
access-list 190 permit ip any 0.1.1.2 255.0.0.0
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
transport input all
exception data-corruption buffer truncate
scheduler allocate 20000 1000
end
I ping 100 packets via this router. the counts are getting incremented as follows,
c2921#sh policy-map int g0/0
GigabitEthernet0/0
  Service-policy output: pdestip
    Class-map: cdestip (match-all)
      0 packets, 0 bytes
      30 second offered rate 0000 bps, drop rate 0000 bps
      Match: access-group 190
      QoS Set
        dscp ef
          Packets marked 0
    Class-map: class-default (match-any)
      1 packets, 60 bytes
      Match: any
c2921#sh int g0/0 | i pack
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     102 packets input, 12332 bytes, 0 no buffer
     102 packets output, 11520 bytes, 0 underruns
c2921#
These packet link type is LINK_IEEE_SPANNING ( 19 ).
can you explain how its happening like this? Why the counters not getting incremented in policy attached in g0/0?
