Layer 3 to Layer 2 Cross Vlan
DocSkyhawk
I am having an issue trying to get IP routing working using a layer 3 switch as a core and layer 2 switches in IDFs.  The Core(layer 3) has several VLANs on it each with the IP address on the vlan interface.  There are several hosts on each of the vlans directly to the core and IP routing is working great.  I can ping each host across the vlans/subnets.  Example:  Vlan 10: IP 10.10.10.200 -> gateway to 10.10.10.1 pings vlan host 10.10.20.200 w/10.10.20.1 gateway and vice versa.  This switch seems fine.
Port g0/1 is setup as a trunk with native vlan 100 to switch #2 (layer 2) with all of the same vlans.  The port on switch 2 is set to trunk with native vlan 100 as well. Similar devices are on that switch on the same subnets matching the vlans.  Any host on switch 2 can ping any host or interface on switch 1(layer 3) but can not ping other vlans on its own switch.(yes the hosts have their DG set to the vlan interface on the layer 3).
BTW this is on Packet Tracer right now as tests.  I ran it in simulation and when I ping from the layer 2 switch side hosts, the packet makes to the the switch->L3 switch->then the other host and responds no matter what vlan/host.  When I ping from the layer 3 side, the packet gets to the the gateway -> gets to the layer 2 switch -> to the host, but fails.  If I change that hosts subnet to 255.255.0.0, it works so it has something to do with it not wanting to talk to other subnets on the layer 2 side.  It will talk to other subnets on layer 3.  Any help would be great.
Hello
just for clarification make sure your L3 core has ip routing enabled and disabled on all l2 switches
All L2 vlans  are populated in the access switches cap database
Kind Regards
Paul
DocSkyhawk
Current configuration : 2161 bytes
version 16.3.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Office1-CR-01
no ip cef
ip routing
no ipv6 cef
spanning-tree mode pvst
interface GigabitEthernet1/0/1
switchport trunk native vlan 60
switchport mode trunk
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
switchport access vlan 10
interface GigabitEthernet1/0/6
switchport access vlan 20
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
switchport access vlan 5
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface Vlan1
no ip address
shutdown
interface Vlan5
mac-address 00e0.8f35.5c02
ip address 10.10.5.1 255.255.255.0
interface Vlan10
mac-address 00e0.8f35.5c03
ip address 10.10.10.1 255.255.255.0
interface Vlan20
mac-address 00e0.8f35.5c04
ip address 10.10.20.1 255.255.255.0
interface Vlan50
mac-address 00e0.8f35.5c05
ip address 10.10.50.1 255.255.255.0
interface Vlan60
mac-address 00e0.8f35.5c06
ip address 10.10.60.1 255.255.255.0
interface Vlan100
mac-address 00e0.8f35.5c07
ip address 10.10.100.1 255.255.255.0
interface Vlan500
mac-address 00e0.8f35.5c08
no ip address
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
DocSkyhawk
Layer 2.  I put ip addresses on some of the vlans as tests but it didn't change anything.
Building configuration...
Current configuration : 1753 bytes
version 12.2
hostname DC-RACK-1
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
switchport access vlan 50
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan5
mac-address 0009.7c42.3101
no ip address
interface Vlan10
mac-address 0009.7c42.3102
ip address 10.10.10.3 255.255.255.0
interface Vlan20
mac-address 0009.7c42.3103
ip address 10.10.20.5 255.255.255.0
interface Vlan50
mac-address 0009.7c42.3104
no ip address
interface Vlan60
mac-address 0009.7c42.3105
no ip address
interface Vlan100
mac-address 0009.7c42.3106
ip address 10.10.100.2 255.255.255.0
interface Vlan500
mac-address 0009.7c42.3107
no ip address
line con 0
line vty 0 4
login
line vty 5 15
login
end
Hello
whatever switch is your L3 switch -
enable ip routing
keep the L3 svi
make sure l2 vlans are populated in vty database
trunk to all access layer layer switches allowing all vlans
On all access switch remove the l3 svi interfaces
disable up routing
trunk to core seitch allowing all vlans
Kind Regards
Paul
