layer 3 untagged with trunk connectivity
i have core switch connected to firewall
the interface in core configuration is
interface Ethernet103/1/24
description PA-VM2 -VSwitch2
switchport
switchport mode trunk
no shutdown
interface Vlan3
no ip redirects
ip address 10.153.16.9/21
description Gateway_Of_Server_Zone
no shutdown
and from fw it is untagged interface L3 with ip 10.153.16.8
is that is possible? how they communicate in the switch port is not layer 3?
Seb Rupik
This would not work as you want.
On a trunk port (eth103/1/4) the default native VLAN is 1 . Any un-tagged traffic arriving on this swithport will be tagged with VLAN1, therefore it will not reach your VLAN3 SVI.
To fix this either create a sub-interface on the firewall and correctly tag the traffic, or change the the native VLAN config on the switch:
int Eth103/1/4
  switchport trunk native vlan 3
cheers,
Seb.
Seb Rupik
int Eth103/1/4
cheers,
Seb.
