Layer 3 vlans up up
Jonathancert_2
Level 4
Level 4
I am way behind the times when it comes to layer three switching.  I didn't have a problem doing inter-vlan routing but recently i was configuring a C4900M with a VLAN and noticed that the VLAN would not come up unless a device was connected the the applied ports of the VLAN.  For example, if I made at:
(config)# Inter VLAN 400
until i applied it to a interface
(config-if)#switchport access vlan 400
and an active broadcasting device to the port, the VLAN is down hard.
Is this normal?
P.S.  The C4900M is in transparent mode and the managment VLAN is the only VLAN being trunked to my 6509
Lei Tian
That is normal, SVI will not come up unless you have active instance for that VLAN.
HTH,
Lei Tian
Lei Tian
HTH,
Lei Tian
Thanks.  That would explain why when I add VLAN 400 to my trunking interface it comes up.
