layer3 switch not routing
Joli Martinez
Level 5
Level 5
I have a 3550 l3 switch configured as follows:
vlan 10 ports 1-10
vlan 21 ports 11-20
vlan 30 port 21-30
vlan 40 ports 31-40
default vlan should be vlan 21
I have the servers, switch and router connected to vlan 21.  Vlan 21 works great I can browse the internet, but I cannot ping any other vlans. router is connected to fa0/19
[code]
Building configuration...
Current configuration : 4833 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname L3Switch
username admin privilege 15 password 7 03554A0A1C5D365F56
no aaa new-model
ip subnet-zero
ip routing
no ip domain-lookup
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
switchport access vlan 21
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
switchport access vlan 30
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
switchport access vlan 40
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
description TRUNK TO L3 ROUTER
switchport mode trunk
interface GigabitEthernet0/1
switchport mode dynamic desirable
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 10.105.10.254 255.255.255.0
ip helper-address 10.105.21.1
interface Vlan21
ip address 10.105.21.251 255.255.255.0
interface Vlan30
ip address 10.105.30.254 255.255.255.0
interface Vlan40
ip address 10.105.40.254 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.105.21.254
ip http server
ip http secure-server
control-plane
line con 0
logging synchronous
line vty 0 4
logging synchronous
login local
transport input telnet
line vty 5 15
no login
end
[/code]
Access-list 1permit on the router defines nat for only the .21 subnet. That is your problem.
11 Replies 11
Reza Sharifi
I am assuming 10.105.21.254 is the router's IP address.  Can you post the router's config?
Jeff Van Houten
Level 11
Level 11
Are the remaining Vlans defined in the vlan database?
Kindly provide ouput of
1/ sh int trunk
2/ sh vlans
3/ sh mac-address-table
4/ sh int vlan10 (vlan21, vlan30, vlan40)
Regards # Mahesh
Joli Martinez
Level 5
Level 5
here is the config to the router, but vlan 21 works and I have internet access, the problem is the routing between the vlans.
[code]
no service pad
hostname p_router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
no ip domain lookup
ip domain name joli.local
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
ip address 10.105.21.254 255.255.255.0
ip nat inside
ip route 0.0.0.0 0.0.0.0 dhcp
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 10.105.21.1 21 interface FastEthernet4 21
ip nat inside source static tcp 10.105.21.1 158 interface FastEthernet4 158
ip nat inside source static tcp 10.105.21.254 22 interface FastEthernet4 22
ip nat inside source static tcp 10.105.21.1 80 interface FastEthernet4 80
ip nat inside source static tcp 10.105.21.2 3389 interface FastEthernet4 3389
ip nat inside source static tcp 10.105.21.250 23 interface FastEthernet4 23
access-list 1 permit 10.105.21.0 0.0.0.255
access-list 23 permit any
access-list 100 remark WAN
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 permit udp any eq domain any
access-list 101 remark ADD PORT FORWARDING STATEMENT HERE
access-list 101 remark permit tcp any any eq port
access-list 101 permit tcp any any eq 22
access-list 101 permit tcp any any eq telnet
access-list 101 permit tcp any any eq ftp
access-list 101 permit tcp any any eq 158
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 permit tcp any eq domain any
control-plane
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
access-class 23 in
login local
transport input ssh
scheduler max-task-time 5000
end
[/code]
Joli Martinez
Level 5
Level 5
here are all outputs.  sh int trunk is empty and right now there are only two active vlans 21 and 30
[code]
L3Switch#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/41, Fa0/42, Fa0/43, Fa0/44
                                                Fa0/45, Fa0/46, Fa0/47, Fa0/48
                                                Gi0/1, Gi0/2
10   VOICE                            active    Fa0/1, Fa0/2, Fa0/3, Fa0/4
                                                Fa0/5, Fa0/6, Fa0/7, Fa0/8
                                                Fa0/9, Fa0/10
21   NETWORK/SERVERS                  active    Fa0/11, Fa0/12, Fa0/13, Fa0/14
                                                Fa0/15, Fa0/16, Fa0/17, Fa0/18
                                                Fa0/19, Fa0/20
30   WORKSTATIONS                     active    Fa0/21, Fa0/22, Fa0/23, Fa0/24
                                                Fa0/25, Fa0/26, Fa0/27, Fa0/28
                                                Fa0/29, Fa0/30
40   QA                               active    Fa0/31, Fa0/32, Fa0/33, Fa0/34
                                                Fa0/35, Fa0/36, Fa0/37, Fa0/38
                                                Fa0/39, Fa0/40
L3Switch#sh mac-ad
L3Switch#sh mac-address-table
          Mac Address Table
Vlan    Mac Address       Type        Ports
All    0016.c755.7c80    STATIC      CPU
All    0016.c755.7c81    STATIC      CPU
All    0016.c755.7c82    STATIC      CPU
All    0016.c755.7c83    STATIC      CPU
All    0016.c755.7c84    STATIC      CPU
All    0016.c755.7c85    STATIC      CPU
All    0016.c755.7c86    STATIC      CPU
All    0016.c755.7c87    STATIC      CPU
All    0016.c755.7c88    STATIC      CPU
All    0016.c755.7c89    STATIC      CPU
All    0016.c755.7c8a    STATIC      CPU
All    0016.c755.7c8b    STATIC      CPU
All    0016.c755.7c8c    STATIC      CPU
All    0016.c755.7c8d    STATIC      CPU
All    0016.c755.7c8e    STATIC      CPU
All    0016.c755.7c8f    STATIC      CPU
All    0016.c755.7c90    STATIC      CPU
All    0016.c755.7c91    STATIC      CPU
All    0016.c755.7c92    STATIC      CPU
All    0016.c755.7c93    STATIC      CPU
All    0016.c755.7c94    STATIC      CPU
All    0016.c755.7c95    STATIC      CPU
All    0016.c755.7c96    STATIC      CPU
All    0016.c755.7c97    STATIC      CPU
All    0016.c755.7c98    STATIC      CPU
All    0016.c755.7c99    STATIC      CPU
All    0016.c755.7c9a    STATIC      CPU
All    0016.c755.7c9b    STATIC      CPU
All    0016.c755.7c9c    STATIC      CPU
All    0016.c755.7c9d    STATIC      CPU
All    0016.c755.7c9e    STATIC      CPU
All    0016.c755.7c9f    STATIC      CPU
All    0016.c755.7ca0    STATIC      CPU
All    0016.c755.7ca1    STATIC      CPU
All    0016.c755.7ca2    STATIC      CPU
All    0016.c755.7ca3    STATIC      CPU
All    0016.c755.7ca4    STATIC      CPU
All    0016.c755.7ca5    STATIC      CPU
All    0016.c755.7ca6    STATIC      CPU
All    0016.c755.7ca7    STATIC      CPU
All    0016.c755.7ca8    STATIC      CPU
All    0016.c755.7ca9    STATIC      CPU
All    0016.c755.7caa    STATIC      CPU
All    0016.c755.7cab    STATIC      CPU
All    0016.c755.7cac    STATIC      CPU
All    0016.c755.7cad    STATIC      CPU
All    0016.c755.7cae    STATIC      CPU
All    0016.c755.7caf    STATIC      CPU
All    0016.c755.7cb0    STATIC      CPU
All    0016.c755.7cb1    STATIC      CPU
All    0016.c755.7cb2    STATIC      CPU
All    0100.0c00.0000    STATIC      CPU
All    0100.0ccc.cccc    STATIC      CPU
All    0100.0ccc.cccd    STATIC      CPU
All    0180.c200.0000    STATIC      CPU
All    0180.c200.0001    STATIC      CPU
All    0180.c200.0002    STATIC      CPU
All    0180.c200.0003    STATIC      CPU
All    0180.c200.0004    STATIC      CPU
All    0180.c200.0005    STATIC      CPU
All    0180.c200.0006    STATIC      CPU
All    0180.c200.0007    STATIC      CPU
All    0180.c200.0008    STATIC      CPU
All    0180.c200.0009    STATIC      CPU
All    0180.c200.000a    STATIC      CPU
All    0180.c200.000b    STATIC      CPU
All    0180.c200.000c    STATIC      CPU
All    0180.c200.000d    STATIC      CPU
All    0180.c200.000e    STATIC      CPU
All    0180.c200.000f    STATIC      CPU
All    0180.c200.0010    STATIC      CPU
  21    000c.29b9.cde4    DYNAMIC     Fa0/15
  21    000c.29cf.915a    DYNAMIC     Fa0/11
  21    001d.7187.5ed4    DYNAMIC     Fa0/19
  21    c42c.0319.730c    DYNAMIC     Fa0/14
  30    0023.69f6.d24d    DYNAMIC     Fa0/24
  30    0024.be63.bb26    DYNAMIC     Fa0/24
  30    d485.6415.2599    DYNAMIC     Fa0/25
  30    f81e.dfec.ce18    DYNAMIC     Fa0/24
Total Mac Addresses for this criterion: 79
L3Switch#sh int vlan 21
Vlan21 is up, line protocol is up
  Hardware is EtherSVI, address is 0016.c755.7c80 (bia 0016.c755.7c80)
  Internet address is 10.105.21.251/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Last input 00:00:13, output 00:00:13, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     1442 packets input, 251369 bytes, 0 no buffer
     Received 0 broadcasts (200 IP multicast)
     1835 packets output, 464959 bytes, 0 underruns
     0 output errors, 0 interface resets
L3Switch#sh int vlan 30
Vlan30 is up, line protocol is up
  Internet address is 10.105.30.254/24
  Last input 00:00:04, output 01:28:45, output hang never
     4796 packets input, 1476249 bytes, 0 no buffer
     Received 0 broadcasts (337 IP multicast)
     33 packets output, 2589 bytes, 0 underruns
[/code]
Can you enable "ip routing" on the switch and test again?
no i can not ping 10.105.30.254 from the 21 vlan
added the route to the router and everything is working.
thx
You are also going to have to define static routes on the router for the switch subnets using the switch ip address as the gateway.
fb_webuser
Level 11
Level 11
Look at the routing table. "show ip route" Are you using a routing protocol? "show ip protocols"
Posted by WebUser Robert Hastings from Cisco Support Community App
