LED's on a Cisco 6506
JAYESH RAMAIYA
Does anyone know any commands to see if an LED is working on a specific port on a Cisco 6506. We currently have a port with no light showing but I know that this is live and transmitting traffic.
InayathUlla Sharieff
Hi Jayesh,
There is no command as such which shows if an LED is working on a specific port on switch.
But you can use Cisco view component(Cisco works) to view the device GUI kind of thing were you can see the ports status.
Inayath
