License for load balance
hello,
I would like know, what license is necessary to employ a load-balance in a 2911 router. I have these licenses bellow, can i configure an load balance?In this cenario we have two links with an ISP.
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(2)T1, RELEASE SOFTWARE (fc1)
Cisco CISCO2911/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FTX1613AH8D
1 FastEthernet interface
3 Gigabit Ethernet interfaces
1 terminal line
2 Channelized (E1 or T1)/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            uck9          Permanent      uck9
data          None          None           None
Thanks!
alepatte
Hi Rodolfo,
The device 2911 router is Enterprise level and you posted your question in Small Business Forum.  You might consider to ask this question at Enterprise forum to get a better response.
https://supportforums.cisco.com/index.jspa
Sincerely,
Alena Patterson
Cisco SB Engineer
CCNA, CCNA Wireless
