Light in gear on continuously lit
Translator
Community Manager
Community Manager
Hello friends, I have a Catalyst 2960-L 24 port switch. When it turns on it gets a blinking amber light and then it turns on.
I tried to access the switch through the console port and when it starts at the terminal, some strange letters appear. Would you have a factory reset if yes how? And if not, what is the possible solution?
balaji.bandi
Remove the Power cord (if the switch running) and follow below steps :
  • Step 1.- Connect your console cable and power up the cisco switch; then, hold down the MODE button for a few seconds until the initialize prompt appears on the screen.
  • Step 2.- Once you see the prompt, enter the following command: flash_init.
  • Step 3.- Now, list the files in the flash directory and delete config.text and vlan.dat from it.
  • Step 4.- Reboot the switch
BB
Now more lyrics and nothing. Could you help me? 
check the baud rate to be different and test it. or download putty and try.
BB
