12-23-2015 10:47 AM - edited 03-08-2019 03:12 AM
Hi All, I was wondering if there a command to light up a switchport on a switch to indicate to a user?
I did some searching but wasn't able to find that info.
Solved! Go to Solution.
12-23-2015 11:57 AM
Not really.
The lights are indicative of link status and network activity.
The closest you could come would be to shutdown a port (which would make the lights go dark if they were already on).
If a port is already dark then there's no way to make the lights turn on or blink short of connecting a device to establish link.
12-23-2015 11:57 AM
Not really.
