Limitation of vlan number in route-map
tnn-dray
Dear community ,
i have question relevant tovlans  limitation  number under route-map is limited to 32vlans?
we encoutered this issue  on Nexus OS 7K ( 8.2.1) by adding new vlan in the route-map configuration  (below error by adding new vlan)
% Cannot add - exceeding maximum limit of 32 entries per command
any one have the similar issue please ?
Thank you
2 Accepted Solutions
tnn-dray
here an exemple :
switch(config)# route-map MAP permit 1
Switch(config-route-map)# match interface Vlan300
Hello
i got confirmation from cisco TAC:  the limitation is 32entries per sequence
the solution :  add new sequence attached to same route-map
Thank you for your help
7 Replies 7
Hello what are you try to accomplish when you say adding multiple vlans under a route-map?
Kind Regards
Paul
Add new vlan under route-map (which is limited to 32vlans)
Hello
I understand that but why do you need to add multiple vlans to a route-map what is the route map being used for
Kind Regards
Paul
Hello
tnn-dray
here an exemple :
I don't know if this is possible, but you can try to do a range like vlan 200-300.
/mikael
Thank you for your feedback, we use random vlan and we don't have any range to be sepcified
i think new bug because it was not mentionned  in PBR limitation guidline : Cisco Nexus 7000 Series NX-OS Unicast Routing Configuration Guide - Configuring Policy-Based Routing [Cisco Nexus 7000 Series Switches] - Cisco
BR
